Playback failures. Books never start and status circle loops around play button.
All failures are AAC m4b files, but many AAC m4b work fine.
Upload description: Playback failures
Transcoder option toggling did not fix issue.
Plex
Tolriq
February 14, 2025, 10:23am
2
It seems all the files that errors are offline cached.
Did you enable transcode for the downloads ?
All the failing files are also 96Khz that the device internal decoder says is not supported but the device says it support up to 192K …
There’s something odd here. Can you upload one of those files to https://upload.symfonium.app and say when done so I can try to repro?
And do you use the official Google ROM or a custom one?
sent w/ more info
google ROM
prefer internal decoder enabled
transcoding engine enabled
add playback cached media to offline rolling cache disabled
playback cache 151mb
offline cache and dl quality - original
Tolriq
February 14, 2025, 11:47am
4
Where did you get those files or how to you generate them ?
I can’t open it with VLC or audacity.
