Playback controls not fully visible on small screen
I’m trying out the app on the Sony NW-A306 Walkman which has a pretty small screen of just 1280 x 720 pixels. When on the extended playback screen not all playback controls are visible, the skip to next track is off screen.
The spacing between the playback control buttons is pretty big and if it was smaller all the controls could easily fit on screen.
Is there an UI setting that controls that spacing? Or even better solution for me, is there a way to disable/remove the back 10/forward 30 buttons as I never use them?
Cheers!
Upload description: Alex_AU
Change the expanded now playing style to Basic or Minimalist.
Well… that was pretty obvious. Thanks!
