I would like an option, so that, if while listening to music, the app gets paused due to a phone call, it stays paused after the call is over.
I sometimes may remove my headphones to speak on the phone, so the music starts playing from the loudspeaker afterwards.
Poweramp has an option for this as well.
Tolriq
2
This requires permissions that I do no want to add.
What I do do eventually is an option to make audio focus loss permanent so no auto play when focus is regained.
i find it a useful feature, but if you think it shouldn’t be added, that’s alright!
Tolriq
4
That’s not what I said, I said it requires a permission that is invasive and proposed an alternative.
The alternative would do mostly the same but for any long focus loss not only calls.
i must misunderstood your first response, then. sorry!
If it is possible to be implemented in the alternative way you mentioned, for my use case, i think it would be alright.
