"Path and File" smart filter does not work for Album Artists & All Artists
I have a single Plex media provider with multiple libraries. In Symfonium, I am using the Library navigation and creating a smart filter where “path and file” starts with “/data/media/music/FLAC/”. This works as expected in the Album and Tracks view. But it returns no results in Album Artists, All Artists, and Compilations views.
I have tried different variations, I.e. “contains FLAC” or lowercase. I’ve also tried “not contains.” No matter what I try, no results are returned.
I’ve tried on a Pixel 10 Pro XL and a Google Streamer 4K.
Android TV
Plex
  1. Configure a Plex media source
  2. Go to Library
  3. Select Album Artists
  4. Select Filter Options
  5. Under Smart Filter, select Add Rule
  6. In the Select Filter Target under Track select “Path and file”
  7. Select “contains” and enter a string that you know will produce results.
  8. Save the filter and activate it
  9. No results will be returned
Path and file smart filter does not work for Album artist or all artists
Thanks will be fixed.
