The password field in the Restore Backup view is smaller than usual and does not allow the text to be displayed.
Upload description: Small password field
- This is a small screen: 3.6in
- I was able to replicate this in 11.0.0 and 11.1.0. I did not see this issue in 10.1.0. I did not test 10.1.5
- The password field in the Create Backup view looks fine.
- This is just cosmetic issue since the field works properly if you know what you are typing
Just click on any existing backup to open the Restore view
