Partially incomplete surround sound albums after scanning the library
I recently transitioned to using SMB for my music and audiobooks, as Jellyfin’s latest major update still causes the same known issues. This new setup initially appeared to function well, but I’ve since observed that certain albums are not displaying all their tracks, even after rescanning. While most albums are scanned perfectly, I’ve encountered difficulties with some surround sound audiobooks, which seem to be incomplete after scanning. My initial hypothesis was that the container format might be incompatible; for instance, Dolby Atmos content in .mka container consistently only scans the first track. However, I then noticed that an Opus 5.1 audiobook also had only 32 out of 39 tracks, which led me to reconsider my initial thought, especially since nearly all my music is in Opus format and scans without any problems. Could this issue be specifically related to non-stereo audio files or is there something else I am missing?
Upload description: janik
I also noticed that the “scanning files tags” phase ist very fast up until a certain point towards the end where it becomes pretty slow. maybe that is the point at wich the app is trying to handle the albums that end up being incomplete?
the files i noticed to be incomplete are:
  • opus 5.1 around 448 kb/s in .opus
  • Dolby Digital Plus with dolby atmos with 6 channels around 768 kb/s in .mka container
  • AC3 5.1 at around 640 kb/s in .mka container
all of them are in the same directory with all of my other audiobooks, just addes normally and tried to sync
Samba
It timeout reading the files
2026-03-15 16:58:50.698 Error SmbStreamDataReader  Error reading Hörspiele/J. K. Rowling/J. K. Rowling - Harry Potter and the Prisoner of Azkaban (Full-Cast Edition, AC3 5.1 Mix, 2026)/Harry Potter and the Prisoner of Azkaban (Full-Cast Edition) AAC 6ch - J.K. Rowling - 20 - Chapter Nineteen - The Servant of Lord Voldemort - 2026-01-22_15;03;45.460.mka
Can you upload the file to https://upload.symfonium.app so I can see ?
Thank you for looking into it! I just uploaded the file you referenced.
Thanks will be fixed in next release.
