An option in the settings which will allow to set a preference or toggle between embedded and external lyrics.
I have a ton of music files which have plain text embedded lyrics. On a later date I had used a 3rd party app that added synced lyrics to all my songs in the form of external lrc files alongside the flac files. Now I noticed that symfonium is showing me the embedded lyrics only. It would be nice if there was a setting to toggle between the two.
Option to toggle between embedded and external lyrics.
I once again refreshed the media on Plex and also checked plexamp which does show me the synced lyrics. But the same song when played on symfonium does not display the external synced lyrics. I’ve uploaded the logs from within the app entering my nickname ‘everything13’
I have uploaded the .flac and also the external .lrc file at the above link.
I am using the latest beta version of symfonium. Also, I was able to replicate this issue using another android device running the beta version as well and connected to the same plex server
Nope, I have no form of offline cache or downloads enabled. I’ll just do some troubleshooting to see if something on my side is causing the issue.
But just coming back to my original feature request, would it be possible to add a toggle to force symfonium to use either the embedded or external lyrics as per user preference?
Got it. Thanks for looking into this!
I ended up deleting those albums and re-downloading a version that did not have any embedded lyrics. And then after one library refresh on plex, all is working well as expected, I can see synced lyrics on symfonium!
Tried that initially but idk for whatever reason it was not working. So instead of wasting time figuring that out, I just re-downloaded and now I am all set
