Option to recognise singular tracks as singles
I like that the artist page divides songs into “albums”, “singles”, “compilations”, “soundtracks”, “appears on” etc based on it’s tags, it’s great feature. However some of these divisions aren’t accessible due to my songs not having the appropriate tags. This now means that the album division would include both albums and tracks that should be divided as singles. My music library on my phone is 23,000+ tracks in total and at least 2,000 total albums so re-tagging them for these divisions to reflect is not feasible. A mitigating solution would be to allow an option for singular tracks to be recognised as singles.
Brought Benefits:
It would declutter the albums division for A LOT of artists.
Screenshot 1
This is the current view on Symfonium showing both singles and albums under the albums division.
Screenshot 2
This is the artist page on Oto Music showing that singular tracks are automatically designated as singles.
Screenshot 3
This is the singles division on Oto Music.
What are the disc and track values for those albums ?
Track 01, Disc 01.
It’s the same for all my singles though it doesn’t matter on Oto music, it just recognises singular tracks as singles.
I’d suggest you use musicbrainz releasetype for this. Making assumptions merely based on the track count would lead to a lot of false positives.
In Jazz for example it’s quite common to have an entire album of 50+ minutes that’s one continous track/jam. That is by no means a single.
This one for example.
I know about and understand the false positives though that’s why I asked for the option, and that’s why I showed oto music as the example.
Plus I noted my 23, 000+ song library. I’m not willing to engage in tagging all of my library now especially considering size and the disparity it would bring between my PC library too.
MusicBee is your best bet, I’d suggest you appropriate tag your music collection once for all for avoid future issues, but for tag all those tracks as singles just download the software, (make a backup of some tracks for testing before tag all the tracks), scan your music folders, sort your albums by Album Track Count, select all the albums with 1 track, right click> Edit, Tags (2) tab there will be extra fields (common and custom), select RELEASE TYPE and tag them as Singles, click on Save icon. This is NOT reversible, that’s why you have to do your testings before.
MP3Tag can solve this too using Filter function but MusicBee method is way more simple
I’m not trying to be rude or anything but your library size is on the smaller side. You should be able to fairly quickly open it in its entirety in Mp3tag for example.
There you could apply this filter (replace %tracktotal% with another variable if you used %totaltracks% for example):
(%track% IS 1 OR %track% IS 01) AND (%tracktotal% IS 1 OR %tracktotal% IS 01) AND %tracktotal% PRESENT
That would only display those tracks with track number 1 and tracktotal 1. Then you could sort these by duration and decide on a length that you no longer want to count as a single. Select the rest of the files, add a MUSICBRAINZ_ALBUMTYPE of Single and you should be done in a couple minutes.
With my library size I can’t even open it in its entirety as it would take days and the last time I tried, it made Mp3tag crash.
Thanks for explain MP3tag method, now he has 2 ways to tag his music collection. MP3Tag have Undo action if accidentally tagged wrong tracks.
@Tolriq any reason for not implementing?:folded_hands:t6:
The feature could be more generic like MusicBee’s album grouping, which allows you to group albums based on a given physical or virtual tag:
I use MusicBee’s Grouping physical tag, which maps to the CONTENTGROUP atom for M4A files, but nothing prevents you from using a different tag. Furthermore, I use zero‑width spaces to tweak the sorting such that “Studio” and “Studio - Cover” values appear at the top.
The MEDIATYPE tag would be a better fit for this.
This basic option would also make my life easier…
If your comfortable with CLI, beets can auto tag according to user defined config rather accurately and efficiently. 23k songs should be taggable rather easily by leaving beets to run over night. From my experience, not having proper tags will bite you in the ass at some point down the line. Filtering, sorting, identification for example what a headache if there is no metadata to pull information from.
Thats also why before music ever enters my music server it gets proper tags, artwork etc. Its extra work, but totally worth it in my opinion.
