Option to persist Smart Flow Mode across media queues
Add an optional setting to automatically apply the last-used Smart Flow mode to newly-created media queues.
Users who consistently use the same Smart Flow mode currently need to manually re-enable it whenever a new queue is created.
For example, my typical workflow is:
Create a Radio Mix (AudioMuse AI)
Enable Transition Maestro (or Steady Vibes)
Listen
When I create another Radio Mix later, I generally want the same Smart Flow mode again, so having to reselect it each time introduces a small amount of repetitive friction.
A possible implementation could be similar to Settings > Playback > Retain player state.
When enabled, Symfonium would remember the last-used Smart Flow mode and automatically apply it to newly-created queues.
Default behaviour would remain unchanged for existing users.
My listening habits have evolved to rely heavily on AudioMuse AI, Radio Mixes and Smart Flow. In practice, Smart Flow has become part of the listening workflow rather than an occasional queue modification.
Related discussions:
Reddit discussion: https://www.reddit.com/r/Symfonium/comments/1jk7tbe/is_there_a_way_to_make_smart_queueflow_enabled_by/
Android Auto / Radio Mix feature request: Its another Android Auto Radio Mix request (with Audiomuse) - #2 by njodoin
Great to see this has been marked as implemented, thanks!
Could you let me know which version includes it (or will include it), and where the setting lives? I’d like to give it a try as soon as it’s available.
ETA: This is in beta 7, released today, and the option is in: Settings > Playback > Playback > Remember Smart Flow Mode.
I’ve done some quick tests and it looks to be working fine - so many thanks for adding this to the app :slight_smile:
