Add an option (as I don’t think it fits every use case) to enable the queue to stay at the same place when re-opening the queue.
There is a button to scroll the list to the currently playing song, so it would make sense for some use cases that the queue would stay at the same position.
When listening to a song, I scroll down the queue to find the next song I want to listen to, and close the queue to rate the song. But when I re-open the queue it resets to the current song playing position.
I know you can move songs to the next play position, but it means that you have to scroll down even further the next time you scroll the queue.
You can scroll the queue at the position where a song you want to listen to next is located, get back on the now playing page and re-open the queue at the same place to play the song in question.
