Please add the new MD3 floating navigation bar as a navigation style.
It adds more options for bottom navigation styles.
It adds a stylish option to use for navigating the app.
Screenshot 1 is the current material design implementation. Screenshot 2 is an example of the floating navigation bar. It should basically have all the colour characteristics of the current implementation but it should look like the floating bar. Also the selections should still be pill shaped rather than circular, see Screenshot 3. As for which button would be separated, it should always be the last one according to number (so where there’s 3 buttons, #3 would be separated. Where there’s 4, #4 would be separated.)
