Option for custom string colours
Sequel to my question in the discussion section, I would like the option to select different colours for each string using a colour picker. It would also be useful for the buttons, volume slider and progress bar.
It helps especially with contrast issues depending on the now playing theme configuration especially when the theme blocks out the words on a string.
It adds another layer of customization granting users the opportunity to set any custom preferred colour of their choice.
It could just be a “custom” option under the string colour options and tapping it would bring up a colour picker and an RGB/HSL picker as is already implemented elsewhere on the app.
Screenshot 1 is the app’s colour picker via the theme section and Screenshot 2 is the RGB/HSL picker via the themes section.
