when tapping the “more” button at the top right of a section on the home screen, it would open a normal search with the given parameters set.
when im on the home screen and i tap the “more” button on the last played tracks/albums section, or the recently added or favorite albums sections (etc, tho i didnt try all of them), i would often like to continue editing the “search” & generally just have that double as a way to get to the tracks / albums / artists category screens.
same for “favorite internet radios” - it would be nice to get from the home screen to the radios screen, looking at favorites by default from that flow and then also be able to switch to viewing all radios.
right now when i tap to see more, im taken to a screen that is like the regular albums/tracks/artists/radios screen in seemingly every way, except i can’t sort the content as usual, or do the “hide small albums/artists” kind of general filtering (as would be particularly desirable with f.e recently added albums), and i cant easily change my mind and decide to look at f.e last played instead of favorites without going back/navigating to a different screen, which is a bit cumbersome and makes it hard to come up with an “optimal” layout.
makes everything feel more unified, integrated and easier to use.
thank you for reading ![]()
