I Just installed Symfonium today and want to utilise the dynamic widget. My problem is that the opacity feature does not seem to work for me. If I understand correctly the the lower bar with play controls should be more or less transparent when selecting percentage in the widget settings. But on my phone there is no change whatsoever.
My phone is a Galaxy 10e with Android 12 and I am using dark theme.
Upload description: clriis / Opacity/Transparency for Widget
Samba
