Hi,
I’m using navidrome with my family and my account is an admin on the server. Due to how the subsonic API works, the getPlaylists endpoint returns every playlist on my server, including private playlists from other users.
It’d be great if there was a way to filter them out from the playlist import screen of Symfonium.
Since my account can see every playlist that exists on the server, the import list gets cluttered with playlists my family members are not sharing.
It’d be easier to import the playlists I want to sync on Symfonium
Other application solutions
Navidrome confirmed that the API endpoint’s behavior is conform to the spec : [Bug]: Private playlist shows up in shared playlists of admin users · Issue #4498 · navidrome/navidrome · GitHub and they feel it’s up to the client to provide a way to filter the private playlists out (they will change their UI to reflect this as well)
All
As per the Subsonic spec it should not be too hard to differentiate my playlists / shared playlist / private playlists I can see because I’m admin : getPlaylists | OpenSubsonic
I should be able to see the playlist I own (cf the owner key) and the public playlist (where "public": true) and not the ones where the owner is not my account and "public": false
"subsonic-response": {
"status": "ok",
"version": "1.16.1",
"playlists": {
"playlist": [
"id": "800000003",
"name": "random - admin - private (admin)",
"owner": "admin",
"public": false,
"created": "2021-02-23T04:35:38+00:00",
"changed": "2021-02-23T04:35:38+00:00",
"songCount": 43,
"duration": 17875
"id": "800000002",
"name": "random - admin - public (admin)",
"owner": "admin",
"public": true,
"created": "2021-02-23T04:34:56+00:00",
"changed": "2021-02-23T04:34:56+00:00",
"songCount": 43,
"duration": 17786
