One licence for phone and Android TV?
All the dozens of apps I have installed on my phone and Google TV and Android TV devices over the years have allowed me to buy one license that I can use on both devices… I saw some post on this forum that seemed to imply that this wasn’t the case with Symfonium? What is the situation with one user, several devices?
Android TV
No steps needed.
It is annoying that I have to supply a log for something that has nothing to do with my particular system… so it seems to be designed to discourage people from posting?
Log unnecessary.
You use support section for not support so well :wink:
And you seem to refer to a random unknown comment instead of the FAQ that clearly explains that Google licences are tied to Google account and works on multiple devices.
Thanks for clarifying… I did look in the FAQ and because this info is right at the top, and it mentioned some special license system and the restriction moving from one device to another, it seemed to me like this unusual licensing system was what you were using… but in fact it’s a normal license, where I can use the license on both my Android TV and Phone… Thanks.
BTW of my comment on Google Play about the interface flow using a TV remote, I will perhaps do a little video sometime… perhaps I should get on the Beta!
Cheers, Mark. PS enjoy your holiday!!
