I installed Symfonium on my Android TV and it works well, except that sometimes, when a new song starts, there is no sound. I can tell the song is playing, but it’s like I’m on mute. To fix it, what I have to do is go to the Equalizer - DSP menu, and turn off the Processing engine (I’m using custom EQ settings, using the 15-band EQ, the Virtualizer, and I have “Enable system equalizer” on; everything else in that section is off). When I do that, the sound comes back. I can then reenable the processing engine and the song will continue playing. This happens every few songs. I’ve been troubleshooting that problem and have enabled debugging. The last time this happened was on 2025-12-13 at 14:26:36, and the song I was attempting to play is “Summer String.mp3”
Upload description: ben1265 log file for song outputting no sound on Android TV
I think that’s all the details I have ![]()
Plex
