Transmitting a timestamp, tracknumber, title, artist, album, album artist and play duration + credentials (I might have forgotten something here) sounds pretty basic to me. Otherwise I wonder how every other player I’ve used managed to master the task.
Not for locally stored files. These are not scrobbled at all as they have no source server. Symfonium literally cannot scrobble these plays without a 3rd party app currently. I was very confused when I first found out that it can’t, because every player I’ve used in the past could.
That would actually fit my needs perfectly fine. I’d disable the multi-scrobbler webhook in jellyfin (I only use jellyfin as a source for Symfonium anyways) and simply use the lastfm scrobbling done in Symfonium both for jellyfin and plays of local files.
I’ve also configured my lastfm account as a source in multi-scrobbler so once the scrobbles end up in lastfm, multi-scrobbler detects them and carries them over to my maloja instance.
That’s the neat thing about multi-scrobbler. I did not change a single thing about my current scrobbling setup (musicbee and plex natively scrobble to lastfm and once the scrobbles are there, multi-scrobbler detects them and adds them to maloja for me).
And I only found out about multi-scrobbler after failing to get scrobbling working in Symfonium. So I guess I have to thank you for that as I would not have had the need to look into multi-scrobbler to solve the problem of Symfonium lacking a scrobbling function otherwise.
Using a different source where the scrobbling on the server side works is sadly not an option for me either as both plex and navidrome do not properly use multi value album artist tags and cover art, which render them useless to me. At that point I can just as well use plexamp and be done with it.
Not really. I just want a fallback to get correct scrobble data to one source (lastfm is probably the most popular one), whichever it might be, so I can let multi-scrobbler do the rest.
I’d be perfectly happy with a global toggle just for lastfm and a warning beside it that having lastfm configured both in Symfonium and in the servers (Plex for example) will lead to duplicate scrobbles.
That way people who do need it can activate it (knowing the risks) and for everyone else nothing has changed.
