Odd timing when playing a gap
I have noticed that when synfonium is playing a song where the band placed a gap the music comes out odd… For example, music should soin like this… Notes [pause] notes… But when synfonium plays them it sounds more like this. Notes [shorter pause] notes. When you have a couple of them in succession it gets quite jarring. Is there anyway to fix this? I turned off gapless playback on upnp but that did not fix the issue.
Ant other suggestions?
Thanks for the help
Drezin
Hey there, buddy! You’re in for a little joke before we dive into the serious stuff. Ready? Here it goes:
Why did the forgetful user cross the road? To get to the mandatory template they forgot to fill out on the other side! :smile:
Alright, now that we’ve had our chuckle, let’s get down to business. It seems like you might have missed filling out a mandatory template that is necessary for me to help you effectively. It happens to the best of us, so don’t sweat it!
But here’s the thing: enabling the “skip silence” option won’t magically fill out that missing template for you. It’s like trying to solve a puzzle by hiding the missing piece under the rug. We need that template to provide you with the best possible assistance.
So, take a moment to double-check and ensure you’ve completed all the required information. That way, I can give you the most accurate and tailored response you deserve.
Remember, even if it feels like a small step, it’s an important one. Let’s make sure we have all the necessary pieces before we dive into the solution.
Now, go ahead, give that mandatory template another shot, and I’ll be here eagerly waiting to help you out!
