Currently, the double tap action applies when input anywhere on the cover panel.
Can you split this in half, so that we can have separate “Left-side double tap” and “Right-side double tap” actions?
Currently we can choose to have Replay or Skip action set here, but not both.
Allows smarter use of Replay & Skip
Double tap on left side to Replay and double tap on right side to Skip forward.
Many other players do this. For example, YouTube Music will Replay 10s when double-tapping the left side and Skip 10s when double-tapping the right side.
I only care about this for the Replay/Skip actions.
For everything else it’s just an extra button, which isn’t that important. So if it’s easier to have a combined option for Replay/Skip, that’s fine with me!
