Now Playing Screen: Rock Solid UI+ (for Phones & Tablets)
Rock Solid UI+
This is my second Now Playing Style.
Built on top of the Rock Solid UI, now enhanced and rounder than ever.
Like the previous style, Plus variant is designed to look great even in tablets as well.
Showcase
Tablet
Tablet
Downloads
Phone: nps-Rock Solid UI Plus for Mobile-20251122_195241-symfonium.json (22.0 KB)
Tablet: nps-Rock Solid UI Plus for Tablet-20251122_195334-symfonium.json (22.0 KB)
Notes
  • This style is designed to work best with the following lyrics settings.
  • The format display is mapped to the following by default:
    • “Hi-Res”: Bit depth is > 16 OR sample rate is > 45
    • “Lossless”: Bit depth is < 17 AND sample rate is < 46 AND bit rate is > 350 kbps
    • “High”: Bit depth is < 17 AND sample rate is < 46 AND bit rate is in the 200-350 kbps range
    • “Standard”: Bit depth is < 17 AND sample rate is < 46 AND bit rate is < 200 kbps
  • The Landscape navigation style in Settings → Interface settings → Navigation and media start must be set to Bottom tabs/compact tabs/navigation bars for the landscape UI to take full screen width as intended.
Dev should add “Pimary Color with “Light” Overlay” to fit this excellent theme lol!!!
Hello! What a beautiful theme !
Invalid theme where i want to import.
It’s a shame, it’s beautiful.
edit : It work from importing to now playing ! THANKS you :slight_smile:
