Using a Google Pixel 10, Symfonium v13.4.0 (127548), with typography set to Symfonium.
After device restart, certain text in the now-playing screen doesn’t display the proper font, such as the song title and artists. The correct font is properly loaded after swapping to and from a track from a different album.
Upload description: tomnjerry74
Sometimes some text’s font seems to load properly while others don’t. Most times, all are using the wrong font.
Screenshot 1: Before restarting the device, title and artists displayed in correct symfonium font.
Screenshot 2: After restarting device, title and artists displayed in incorrect font until steps above are taken to reset the now-playing screen.
- Start a song so the app is in a state of playing.
- Restart the device.
- After restart, open Symfonium and select the mini player to get to the now-playing screen.
- Notice that text items such as song title and artists are rendered with the wrong font that is not chosen in your interface settings.
- Select a track from a different album to play. Then, go back to playing the initial track.
- Note the fonts are fixed and display properly now.
Any provider
