As the title says doing anything on the notification causes it to flash a cyan color for some reason. I’ve tried many other music apps but never encountered this issue before. Device: Samsung note 9 Android 10.
It no longer flashes at all when using the action buttons or flashes cyan when skipping but skipping tracks is still not very smooth. Don’t know if its just me or if that’s normal. When skipping tracks with different cover art that varies greatly in color (esp if its has a white background it seems) the cover art takes a little while to come up sometimes. Occasionally it shows a wrong color and theming before showing the correct one. Don’t know how well I explained that but yeah.
Yeah definitely way less jarring. Seems like it has something to do with how it extracts and/or applies color to dynamically theme the notif for each track. I’ve noticed the notification also briefly “jumps” in size sometimes when displaying some cover art maybe some problem with scaling.
This is more or less normal, the covers can take time to be loaded from the server, but the track is displayed when it start playing.
Since tracks are not always local I can’t delay the notification for the thumb to be loaded as it can be up to 15 seconds to fail to load it.
