Notification color blinking when switching songs
Pressing previous/next/play/pause on now playing notification is causing weird color blinking.
debug-20230414_225341.zip (5.7 KB)
Sounds like a bug on your device with the most recent Google libraries. I do not have much control over there.
That’s unfortunate. I don’t have this issue with any other media player app.
Well I do not have any idea and there’s nowhere that color used in the app.
Unless you use a special custom theme?
I have no idea either where this cyan color comes from. I have a pretty much stock Android (Android One), with no special theming at all.
Was talking about custom Symfonium theme but I suppose also no :frowning:
Never see that behavior so honestly not something I’ll be able to workaround for your device.
Hello!
Have the same issue. My device - Shanling M3 Ultra it uses Android 10 :frowning:
It looks like player updates “notification” each time I touch any button.
At the same time “notifications” from Tidal or Apple Music work good.
I am having this very issue currently Note 9 Android 10. Love the player but I mainly use the notification to change music so this is pretty annoying.
Yeah I don’t have this issue with any other play I’ve tried.
Same issue, it happens with the symfonium default theme too.
Yeah at first I thought it was something I modified in the app but no.
Same issue on Android 11
