When I add two items to the queue (possibly important: the first one has no cover, while the second one does have it)
After the first one finishes playing, the second one “starts” in the notification - the seconds in the progress bar do tick, however, no music is played.
When I open the Symfonium app, the progress bar is stuck at 0
After I pause and unpause it, strange noises can be heard, almost like the file is corrupted maybe?
I have to fast-forward it using the progress bar, then the song plays completely fine
Logs does not show the issue, it can be a ffmpeg or my replain gain processor issue can you provide me those 2 songs or an access to your server with those songs so I can try to reproduce ?
From the logs the second song is mono channel and switching between stereo and mono is probably the cause.
It could be something else possibly, since after I ran them through ffmpeg, keeping the mono/stereo streams, the problem suddenly stopped occurring.
I can send you the files, though i cannot find the option to message you privately.
Ok so get the files and can’t reproduce it properly switch from 1 to 2.
But during the playback of 1 there’s 3 or 4 small glitch/scratch like corrupted file.
Okay, so I just completely uninstalled the app, and after again downloading the files the problem doesn’t appear anymore. I guess it could be a corrupted download maybe?
