No connection to Navidrome in docker
Can’t connect to Navidrome which is installed as container on a Synology Nas. I use the same address, I use in a browser. There is working.
Upload description: bickle70
I setup Navidrome with a reverse Proxy to access it externally via a synology.me address. But for Symfonium it makes no difference. It can’t connect externally or over the home network.
You enter the wrong value it seems you are using a subfolder …
So http://ip:port/navidrome seems to be the url you need to enter.
That did it! Thank you for your support!
