Hello
IS it possible to add radio on the New screen personnalisation for Android auto.
I use to listen radio through synfonium app
Would easier to choice which one i want to listen
Not provided
Not provided
Tolriq
2
It’s already there Library / Internet Radio.
That’s not m’y request
What i will liké IS having a shortcut like this
In order to not have to go in library / radio and then the list if radios
Tolriq
4
Put the library tab as the first one ?
Or you want a new favorite radio in the favorite tab, you could try to take some time to better explain your need.
Yes , i will take some photos tomorrow
So , after having a look at this New Android auto tab , i would liké to have radios in welcome screen
Like in this one
Tolriq
7
The radio is already in the library tab as said there’s no need to duplicate.
IS a tab possible, here, at thé moment , i have to make 4 click to get m’y radios
Thx for adding it in New version
