Navidrome Sleekness
Finished version :slight_smile:
** Requires v14 Beta
And here it is version 1
Few edits to home screen and Album page after new beta release today.
  • Artist name bigger on Album Page
  • Home page shortcuts rearranged
Looks great!
How can I download it?
You need to wait for me to share the JSON file with us. That’s what you need to get that theme and apply it to your Symfonium.
Thanks here is the files, not sure if the playlist covers and Navidrome logo at the top get export with these. So let me know and I can add them here or you can customize yourself.
– Application style
as-Navidrom Sleekness-20260219_070330-symfonium.json (117.5 KB)
– Now Playing screen
nps-Navidrome-20260219_070308-symfonium.json (35.9 KB)
– Theme colour
Basic-20260219_070237.json (2.7 KB)
– Navidrome custom logo for home screen
I love your Home screen! The bright colors and different shapes are really eye-catching, yet still fit together in an orderly way. Nicely done!
Thank you! I am merely but a user of this fantastic app :slight_smile:
Please always post the images in the first post as it’s used for the thread display in the Style part of the forum.
Will edit. I only removed them because it contained the unfinished version. :slight_smile:
Question: how did you get the artist page to look like that? I imported the json files but everything looks sooo different. Not sure if I’m doing something wrong but for me it doesn’t look quite similar to the pictures?
Here is my settings. I think the end result is also dependent on device.
He use the v14 on beta
Yes, Tolriq is correct. I failed to recognise you were in the latest beta version. More things to look forward to in the app - just when you thought everything that exists was already in the app :sob:. Thank you for your work.
I should have put it in the post to be fair.
Edited now to avoid further confusion. V14 is on beta 5 now, so a stable release is probably not far away :wink:
Can you tell me a bit more about some of your smart playlists, like discover weekly and daily mix? I love a smart playlist but I’m rarely creative enough to come up with anything interesting
These are auto generated using the listenbrainz smart playlist plugin for Navidrome. Then I import them to Sysmfonium online first so they get updated automatically.
You could create something with filters also but its not as dynamic as one generated from your actual listening habits.
I also use Audiomuse AIs fingerprint mix to create a unique playlist once a week.
Many thanks. I’ll give them a look
That’s cool! Gonna also look into it. Didn’t realise that the plugin feature would be this useful.
How do I download this because I keep getting invalid file or sm please help
