First of all, thanks to the team for Symfonium, I use it very often and I love it.
Since today, my navidrome music provider is not reachable by Symfonium, it appears offline. I am using 11.3.0, I was using navidrome 0.53.1 and I updated to 0.53.3 with no success.
From the logs, it seems to not be reachable, although I can access navidrome webui from my laptop on the same network.
Any suggestions ?
Thanks in advance
Upload description: newmonade
navidrome is reachable through webui
I tried deleting the provider, emptying the cache and setting a new provider again.
java.net.SocketTimeoutException: failed to connect to /192.168.1.4 (port 4533) from /192.168.1.62 (port 47434) after 5000ms
Your device tells Symfonium that it can’t connect to the ip and port in less than 5 seconds. There’s nothing I can do from Symfonium side to workaround that.
