Navidrome paylist not updated by Symfonium
I freshly imported a playlist from my Navidrome as “online first”.
I tried to add a song to the playlist and received an “error sync”.
cc. @deluan
Upload description: Username: vurt Issue: Navidrome not updating online playlist Symfonium log attached.
Navidrome log: time="2025-02-15T15:56:53Z" level=info msg="Now Playing" artist="Eelke Kleijn" player="Symfonium [Symfonium/Android]" requestId=02985631574e/0M1kiHAFHp-000633 title="DAYS like NIGHTS 378 - Complot Outdoor, Santa Fe, Argentina" user=vurt time="2025-02-15T15:56:59Z" level=info msg="Now Playing" artist="Eelke Kleijn" player="Symfonium [Symfonium/Android]" requestId=02985631574e/0M1kiHAFHp-000635 title="DAYS like NIGHTS 378 - Complot Outdoor, Santa Fe, Argentina" user=vurt time="2025-02-15T16:38:27Z" level=warning msg="API: Failed response" endpoint=/rest/updatePlaylist.view error=10 message="missing parameter: 'playlistId'" requestId=02985631574e/0M1kiHAFHp-000737 time="2025-02-15T16:40:18Z" level=info msg="Now Playing" artist="Eelke Kleijn" player="Symfonium [Symfonium/Android]" requestId=02985631574e/0M1kiHAFHp-000750 title="DAYS like NIGHTS 378 - Complot Outdoor, Santa Fe, Argentina" user=vurt time="2025-02-15T16:40:58Z" level=warning msg="API: Failed response" endpoint=/rest/updatePlaylist.view error=10 message="missing parameter: 'playlistId'" requestId=02985631574e/0M1kiHAFHp-000761 time="2025-02-15T16:55:10Z" level=warning msg="HTTP: GET http://192.168.1.252:4533/api/transcoding?_end=1000&_order=ASC&_sort=name&_start=0" elapsedTime="58.955µs" httpStatus=401 remoteAddr="192.168.1.50:56802" requestId=02985631574e/0M1kiHAFHp-000800 responseSize=29 time="2025-02-15T16:55:10Z" level=warning msg="HTTP: GET http://192.168.1.252:4533/api/playlist?_end=0&_sort=name&_start=-100" elapsedTime=7.5ms httpStatus=401 remoteAddr="192.168.1.50:56803" requestId=02985631574e/0M1kiHAFHp-000799 responseSize=29 time="2025-02-15T16:55:10Z" level=warning msg="HTTP: GET http://192.168.1.252:4533/api/playlist?_end=15&_order=ASC&_sort=id&_start=0" elapsedTime="56.505µs" httpStatus=401 remoteAddr="192.168.1.50:56802" requestId=02985631574e/0M1kiHAFHp-000801 responseSize=29 time="2025-02-15T16:55:10Z" level=warning msg="HTTP: GET http://192.168.1.252:4533/api/user?_end=0&_order=ASC&_sort=name&_start=0" elapsedTime="27.828µs" httpStatus=401 remoteAddr="192.168.1.50:56803" requestId=02985631574e/0M1kiHAFHp-000804 responseSize=29 time="2025-02-15T16:56:00Z" level=info msg="Loaded translations" languages="[ar bg ca cs da de eo es eu fa fi fr gl hu id it ja ko nl pl pt ru sl sr sv th tr uk zh-Hans zh-Hant]"
For @deluan
The Symfonium side:
SubsonicLogger  --> [271] POST http://xxxx.xxx.net/rest/updatePlaylist.view?u=REDACTED&t=REDACTED&s=REDACTED&v=1.13.0&c=Symfonium&f=json (187-byte body)
SubsonicLogger  --> [271] playlistId=3abe7416-a442-41a0-a0f7-1622a97b884b&songIndexToRemove=0&songIndexToRemove=1&songIndexToRemove=2&songIndexToRemove=3&songIndexToRemove=4&songIndexToRemove=5&songIndexToRemove=6
SubsonicLogger  --> [271] END POST (187-byte body)
SubsonicLogger  <-- [271] 200 https://xxx.xxx.net/rest/updatePlaylist.view?u=REDACTED&t=REDACTED&s=REDACTED&v=1.13.0&c=Symfonium&f=json (9ms, unknown-length body)
SubsonicLogger  <-- [271] {"subsonic-response":{"status":"failed","version":"1.16.1","type":"navidrome","serverVersion":"0.54.4 (73ccfbd8)","openSubsonic":true,"error":{"code":10,"message":"missing parameter: 'playlistId'"}}}
The playlistId is definitively sent.
What version of Navidrome is this? nvm, so it in the log above. Will take a look
I can’t reproduce it. Can you please change Navidrome’s LogLevel to trace and send me the related section of the logs when trying to update the playlist?
Actually I am able to reproduce it, if the request does not have the content-type set to application/x-www-form-urlencoded. @Tolriq can you confirm from the logs that the content-type is set correctly?
No the logs don’t show the header but it’s handled by the http library and since the content is form-url encoded it’s certain it’s there else the call would fail.
Just tested with the demo server of Navidrome and everything works as expected as with my old personal instance.
@vurt do you have a proxy or something in front of your server that could rewrite the headers ?
@Tolriq Ah yes, it is reverse-proxied with nginx.
The Navidrome is installed as a docker on an Unraid NAS and reverse proxied.
Symfonium connects fine to it outside the LAN but I don’t know enough to know what happens between Synfonium and Navidrome via nginx.
@deluan can Navidrome log the headers on it’s side to see what reach it ?
Yes, by setting log level to trace
Hi @deluan , I set the log level to “trace” and this is what I got:
time="2025-02-15T21:05:42Z" level=warning msg="API: Failed response" endpoint=/rest/updatePlaylist.view error=10 message="missing parameter: 'playlistId'" requestId=02985631574e/5T9DMWbuEJ-000186
time="2025-02-15T21:10:36Z" level=warning msg="API: Failed response" endpoint=/rest/updatePlaylist.view error=10 message="missing parameter: 'playlistId'" requestId=02985631574e/5T9DMWbuEJ-000295
You are only posting the error. Please add the full logs for the request. Example:
DEBU[0015] API: New request /rest/updatePlaylist         client=NavidromeUI requestId=Mac.lan/7TOEL9X6di-000002 username=admin version=1.8.0
TRAC[0015] SQL: `SELECT * FROM user WHERE user_name = {:p0} COLLATE NOCASE`  args="map[p0:admin]" elapsedTime="853.666µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=1
TRAC[0015] SQL: `UPDATE user SET last_access_at = {:p0} WHERE id = {:p1}`  args="map[p0:2025-02-15 16:17:20.46454 -0500 EST m=+15.704714335 p1:6f9786e8-3b84-4d9d-865e-1f8dda2682a5]" elapsedTime="527.417µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=1
TRAC[0015] Update user's lastAccessAt                    elapsed=2.2ms requestId=Mac.lan/7TOEL9X6di-000002 username=admin
TRAC[0015] playerId found in cookies                     playerId=aba5499a-0748-49cf-9bae-b49fc941587d requestId=Mac.lan/7TOEL9X6di-000002
TRAC[0015] SQL: `SELECT player.*, user.user_name username FROM player JOIN user ON player.user_id = user.id WHERE player.id = {:p0}`  args="map[p0:aba5499a-0748-49cf-9bae-b49fc941587d]" elapsedTime="981.041µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=1
TRAC[0015] SQL: `UPDATE player SET client = {:p0}, id = {:p1}, ip = {:p2}, last_seen = {:p3}, max_bit_rate = {:p4}, name = {:p5}, report_real_path = {:p6}, scrobble_enabled = {:p7}, transcoding_id = {:p8}, user_agent = {:p9}, user_id = {:p10} WHERE id = {:p11}`  args="map[p0:NavidromeUI p1:aba5499a-0748-49cf-9bae-b49fc941587d p10:6f9786e8-3b84-4d9d-865e-1f8dda2682a5 p11:aba5499a-0748-49cf-9bae-b49fc941587d p2:127.0.0.1 p3:2025-02-15T16:17:20.472275-05:00 p4:0 p5:NavidromeUI [IntelliJ HTTP Client] p6:false p7:true p8: p9:IntelliJ HTTP Client]" elapsedTime="531.083µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=1
DEBU[0015] Updating playlist                             id=30b3d166-0c26-42b7-bbe2-681fbbda04d2 requestId=Mac.lan/7TOEL9X6di-000002
TRAC[0015] -- Adding: '[]'                               requestId=Mac.lan/7TOEL9X6di-000002
TRAC[0015] -- Removing: '[0]'                            requestId=Mac.lan/7TOEL9X6di-000002
TRAC[0015] SQL: `SELECT playlist.*, user.user_name as owner_name FROM playlist JOIN user on user.id = owner_id WHERE (playlist.id = {:p0} AND (1=1))`  args="map[p0:30b3d166-0c26-42b7-bbe2-681fbbda04d2]" elapsedTime="699.792µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=1
TRAC[0015] SQL: `SELECT playlist.*, user.user_name as owner_name FROM playlist JOIN user on user.id = owner_id WHERE (playlist.id = {:p0} AND (1=1))`  args="map[p0:30b3d166-0c26-42b7-bbe2-681fbbda04d2]" elapsedTime="298.25µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=1
TRAC[0015] SQL: `SELECT coalesce(starred, 0) as starred, starred_at, coalesce(play_count, 0) as play_count, play_date, coalesce(rating, 0) as rating, f.*, playlist_tracks.* FROM playlist_tracks LEFT JOIN annotation on (annotation.item_id = media_file_id AND annotation.item_type = 'media_file' AND annotation.user_id = '6f9786e8-3b84-4d9d-865e-1f8dda2682a5') JOIN media_file f on f.id = media_file_id WHERE playlist_id = {:p0} ORDER BY playlist_tracks.id`  args="map[p0:30b3d166-0c26-42b7-bbe2-681fbbda04d2]" elapsedTime=7.2ms requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=31
TRAC[0015] SQL: `SELECT count(*) as exist FROM playlist WHERE (id = {:p0} AND (1=1))`  args="map[p0:30b3d166-0c26-42b7-bbe2-681fbbda04d2]" elapsedTime="155.875µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=1
TRAC[0015] SQL: `UPDATE playlist SET comment = {:p0}, duration = {:p1}, evaluated_at = {:p2}, id = {:p3}, name = {:p4}, owner_id = {:p5}, path = {:p6}, public = {:p7}, size = {:p8}, song_count = {:p9}, sync = {:p10}, updated_at = {:p11} WHERE id = {:p12}`  args="map[p0:Auto-imported from 'yussef.m3u' p1:7410.33 p10:true p11:2025-02-15T16:17:20.494073-05:00 p12:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p2:<nil> p3:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p4:yussef p5:6f9786e8-3b84-4d9d-865e-1f8dda2682a5 p6:/Users/deluan/Music/Picard/yussef.m3u p7:false p8:1070813888 p9:31]" elapsedTime="462.459µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=1
TRAC[0015] SQL: `DELETE FROM playlist_tracks WHERE playlist_id = {:p0}`  args="map[p0:30b3d166-0c26-42b7-bbe2-681fbbda04d2]" elapsedTime="92.208µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=31
TRAC[0015] SQL: `INSERT INTO playlist_tracks (playlist_id,media_file_id,id) VALUES ({:p0},{:p1},{:p2}),({:p3},{:p4},{:p5}),({:p6},{:p7},{:p8}),({:p9},{:p10},{:p11}),({:p12},{:p13},{:p14}),({:p15},{:p16},{:p17}),({:p18},{:p19},{:p20}),({:p21},{:p22},{:p23}),({:p24},{:p25},{:p26}),({:p27},{:p28},{:p29}),({:p30},{:p31},{:p32}),({:p33},{:p34},{:p35}),({:p36},{:p37},{:p38}),({:p39},{:p40},{:p41}),({:p42},{:p43},{:p44}),({:p45},{:p46},{:p47}),({:p48},{:p49},{:p50}),({:p51},{:p52},{:p53}),({:p54},{:p55},{:p56}),({:p57},{:p58},{:p59}),({:p60},{:p61},{:p62}),({:p63},{:p64},{:p65}),({:p66},{:p67},{:p68}),({:p69},{:p70},{:p71}),({:p72},{:p73},{:p74}),({:p75},{:p76},{:p77}),({:p78},{:p79},{:p80}),({:p81},{:p82},{:p83}),({:p84},{:p85},{:p86}),({:p87},{:p88},{:p89})`  args="map[p0:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p1:517cb6295429baa4123a97a217c973e1 p10:7b35b4acd3b2ead425765b92edd71013 p11:4 p12:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p13:0b7cf959a86e860d02066de75f6187c3 p14:5 p15:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p16:b8102798b50325ec4e040c49e4174538 p17:6 p18:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p19:7c9df4d9b053de14ae8ece57193ee035 p2:1 p20:7 p21:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p22:6f9a5149bdea3f8340ae306cf411d994 p23:8 p24:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p25:550472955d6c0b5280c068330fe6c294 p26:9 p27:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p28:053df360495b418fbde46693e22ff653 p29:10 p3:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p30:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p31:966ccc58ad50f2a50f35944f235d67f8 p32:11 p33:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p34:7fdc686997f95ee0580090a3c5ba37e5 p35:12 p36:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p37:11a225797f2990b04142c3c4dfc46abe p38:13 p39:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p4:0cec72db00eaeb2e6052b27c89bc025c p40:1aed50ec237d97cfdd53a219022ae4fe p41:14 p42:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p43:9c7cf72a7430ad6ecd5fe64339713b3c p44:15 p45:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p46:e177248c4ae82032f5d6a8c36f54ce63 p47:16 p48:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p49:7f8918dd5b39475b92a60a99de9351d9 p5:2 p50:17 p51:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p52:674d2382f722b161deba1bd33ab136da p53:18 p54:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p55:2bb62dd15368bfad501e779813e67428 p56:19 p57:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p58:5c2f5c7a1103ba15e6942fe4b5116f0b p59:20 p6:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p60:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p61:7649395d36b6d2a376c945ca6f9ea5fc p62:21 p63:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p64:5a081c2f89662321e799d9adf91a0a1d p65:22 p66:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p67:802d9d8829507c4522509a5f8aa209fb p68:23 p69:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p7:9f940731c4351ea65a1458d652b92082 p70:192366c25ae6a8946a1641f6c2be8a5a p71:24 p72:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p73:dc7bac3704729ea87ca4963272971f3d p74:25 p75:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p76:605030f56891f7ab211b2fe710f2e532 p77:26 p78:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p79:86333730b5c871161146aab89630c909 p8:3 p80:27 p81:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p82:59770d8f8c6b233e44591e600841b608 p83:28 p84:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p85:ac44fd741353a5e739dca182dec53404 p86:29 p87:30b3d166-0c26-42b7-bbe2-681fbbda04d2 p88:d36b1427daa1bbbba72aebfe6bb855f6 p89:30 p9:30b3d166-0c26-42b7-bbe2-681fbbda04d2]" elapsedTime="656.083µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=30
TRAC[0015] SQL: `SELECT coalesce(sum(duration), 0) as duration, coalesce(sum(size), 0) as size, count(*) as count FROM media_file JOIN playlist_tracks f on f.media_file_id = media_file.id WHERE playlist_id = {:p0}`  args="map[p0:30b3d166-0c26-42b7-bbe2-681fbbda04d2]" elapsedTime="287.583µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=1
TRAC[0015] SQL: `UPDATE playlist SET duration = {:p0}, size = {:p1}, song_count = {:p2}, updated_at = {:p3} WHERE id = {:p4}`  args="map[p0:7213.89 p1:1.0340683e+09 p2:30 p3:2025-02-15 16:17:20.510207 -0500 EST m=+15.750381293 p4:30b3d166-0c26-42b7-bbe2-681fbbda04d2]" elapsedTime="136.125µs" requestId=Mac.lan/7TOEL9X6di-000002 rowsAffected=1
DEBU[0015] API: Successful response                      body="{\"subsonic-response\":{\"status\":\"ok\",\"version\":\"1.16.1\",\"type\":\"navidrome\",\"serverVersion\":\"dev\",\"openSubsonic\":true}}" endpoint=/rest/updatePlaylist requestId=Mac.lan/7TOEL9X6di-000002 status=OK
DEBU[0015] HTTP: POST http://localhost:4533/rest/updatePlaylist?u=admin&p=[REDACTED]&f=json&v=1.8.0&c=NavidromeUI  elapsedTime=56.2ms header="{\"Accept\":[\"*/*\"],\"Accept-Encoding\":[\"br, deflate, gzip, x-gzip\"],\"Content-Length\":[\"67\"],\"Content-Type\":[\"application/x-www-form-urlencoded\"],\"Cookie\":[\"nd-player-61646d696e=aba5499a-0748-49cf-9bae-b49fc941587d\"],\"User-Agent\":[\"IntelliJ HTTP Client/IntelliJ IDEA 2024.3.2.2\"]}" httpStatus=200 remoteAddr="127.0.0.1:51465" requestId=Mac.lan/7TOEL9X6di-000002 responseSize=117
It starts with API: New request /rest/updatePlaylist and ends with HTTP: POST http://localhost:4533/rest/updatePlaylist
EDIT: What we are looking for is the HTTP: POST http://localhost:4533/rest/updatePlaylist line, that shows the request headers
Hi @deluan , I restarted Navidrome, this is a fresh log. I can’t seem to find the line you’re referring to. I wonder if it’s my Navidrome config?
Navidrome config:
PlaylistsPath='_Playlists:_Playlists/**'
AutoImportPlaylists=true
RecentlyAddedByModTime=true
EnableTranscodingConfig=true
DefaultTheme='Spotify-ish'
Scanner.GroupAlbumReleases=true
LogLevel = 'trace'
Navidrome log:
 _   _             _     _
| \ | |           (_)   | |
|  \| | __ ___   ___  __| |_ __ ___  _ __ ___   ___
| . ` |/ _` \ \ / / |/ _` | '__/ _ \| '_ ` _ \ / _ \
| |\  | (_| |\ V /| | (_| | | | (_) | | | | | |  __/
\_| \_/\__,_| \_/ |_|\__,_|_|  \___/|_| |_| |_|\___|
                          Version: 0.54.4 (73ccfbd8)
time="2025-02-15T21:31:55Z" level=info msg="goose: no migrations to run. current version: 20241024125533\n"
time="2025-02-15T21:31:55Z" level=info msg="Starting signaler"
time="2025-02-15T21:31:55Z" level=error msg="Agent not available. Check configuration" name=lastfm
time="2025-02-15T21:31:55Z" level=error msg="Agent not available. Check configuration" name=spotify
time="2025-02-15T21:31:55Z" level=info msg="Configuring Media Folder" name="Music Library" path=/music
time="2025-02-15T21:31:55Z" level=info msg="Found ffmpeg" path=/usr/bin/ffmpeg
time="2025-02-15T21:31:55Z" level=info msg="Creating Image cache" maxSize="200 MB" path=/data/cache/images
time="2025-02-15T21:31:55Z" level=info msg="Starting Insight Collector"
time="2025-02-15T21:31:55Z" level=info msg="Starting scheduler"
time="2025-02-15T21:31:55Z" level=warning msg="Periodic backup is DISABLED"
time="2025-02-15T21:31:55Z" level=info msg="Scheduling periodic scan" schedule="@every 1m"
time="2025-02-15T21:31:55Z" level=info msg="Setting Session Timeout" value=24h
time="2025-02-15T21:31:55Z" level=info msg="Login rate limit set" requestLimit=5 windowLength=2
time="2025-02-15T21:31:55Z" level=info msg="Spotify integration is not enabled: missing ID/Secret"
time="2025-02-15T21:31:55Z" level=info msg="Mounting Native API routes" path=/api
time="2025-02-15T21:31:55Z" level=info msg="Creating Transcoding cache" maxSize="100 MB" path=/data/cache/transcoding
time="2025-02-15T21:31:55Z" level=info msg="Mounting Subsonic API routes" path=/rest
time="2025-02-15T21:31:55Z" level=info msg="Mounting Public Endpoints routes" path=/share
time="2025-02-15T21:31:55Z" level=info msg="Mounting LastFM Auth routes" path=/api/lastfm
time="2025-02-15T21:31:55Z" level=info msg="Mounting ListenBrainz Auth routes" path=/api/listenbrainz
time="2025-02-15T21:31:55Z" level=info msg="Mounting Background images routes" path=/backgrounds
time="2025-02-15T21:31:55Z" level=info msg="Mounting WebUI routes" path=/app
time="2025-02-15T21:31:55Z" level=info msg="Creating backgrounds cache" maxSize="100 MB" path=/data/cache/backgrounds
time="2025-02-15T21:31:55Z" level=info msg="Finished initializing cache" cache=Transcoding elapsedTime=9.1ms maxSize=100MB
time="2025-02-15T21:31:55Z" level=info msg="Finished initializing cache" cache=backgrounds elapsedTime=11.3ms maxSize=100MB
time="2025-02-15T21:31:55Z" level=info msg="----> Navidrome server is ready!" address="0.0.0.0:4533" startupTime=160.4ms tlsEnabled=false
time="2025-02-15T21:31:57Z" level=info msg="Configuring Media Folder" name="Music Library" path=/music
time="2025-02-15T21:32:03Z" level=info msg="Finished initializing cache" cache=Image elapsedTime=8.38s maxSize=200MB
time="2025-02-15T21:32:43Z" level=info msg="Now Playing" artist="Anja Schneider" player="Symfonium [Symfonium/Android]" requestId=02985631574e/uUOZ5TxDSq-000007 title="Club Room 354 with Anja Schneider" user=vurt
time="2025-02-15T21:32:44Z" level=info msg="Now Playing" artist="Anja Schneider" player="Symfonium [Symfonium/Android]" requestId=02985631574e/uUOZ5TxDSq-000008 title="Club Room 354 with Anja Schneider" user=vurt
time="2025-02-15T21:32:44Z" level=info msg="Now Playing" artist="Anja Schneider" player="Symfonium [Symfonium/Android]" requestId=02985631574e/uUOZ5TxDSq-000009 title="Club Room 354 with Anja Schneider" user=vurt
time="2025-02-15T21:32:45Z" level=info msg="Now Playing" artist="Anja Schneider" player="Symfonium [Symfonium/Android]" requestId=02985631574e/uUOZ5TxDSq-000010 title="Club Room 354 with Anja Schneider" user=vurt
time="2025-02-15T21:33:33Z" level=warning msg="API: Failed response" endpoint=/rest/updatePlaylist.view error=10 message="missing parameter: 'playlistId'" requestId=02985631574e/uUOZ5TxDSq-000019
Doesn’t seem that Navidrome is loading this config file. The logs you posted here are not trace/debug logs. When trace/debug is active, the first line you should see after the banner is the config file path:
 _   _             _     _
| \ | |           (_)   | |
                                        Version: dev
Loaded configuration from '/home/deluan/development/navidrome/navidrome.toml': &conf.configOptions{
    ConfigFile:                      "/home/deluan/development/navidrome/navidrome.toml",
    Address:                         "0.0.0.0",
    Port:                            4533,
    UnixSocketPerm:                  "0660",
Thank you for the clarification. This is odd, I looked at the docker compose and noticed in the template there is a setting for loglevel, even though I also have a navidrome.toml file.
I got a new log with the proper detail now. It’s too long to post the whole thing, but I searched and found this section:
time="2025-02-15T21:58:00Z" level=debug msg="API: New request /rest/updatePlaylist.view" client=Symfonium requestId=83a493bc950c/Lsil03q9UT-000007 username=vurt version=1.13.0
time="2025-02-15T21:58:00Z" level=trace msg="SQL: `SELECT * FROM user WHERE user_name = {:p0} COLLATE NOCASE`" args="map[p0:vurt]" elapsedTime="171.275µs" requestId=83a493bc950c/Lsil03q9UT-000007 rowsAffected=1
time="2025-02-15T21:58:00Z" level=trace msg="SQL: `SELECT player.*, user.user_name username FROM player JOIN user ON player.user_id = user.id WHERE (client = {:p0} AND user_agent = {:p1} AND user_id = {:p2})`" args="map[p0:Symfonium p1:Symfonium/Android p2:e7d2b8f5-f9e8-4612-a178-37c3b3a82465]" elapsedTime="132.525µs" requestId=83a493bc950c/Lsil03q9UT-000007 rowsAffected=1
time="2025-02-15T21:58:00Z" level=debug msg="Found matching player" client=Symfonium id=49609f78-1c61-42ce-ad26-dcf1b96d8f67 requestId=83a493bc950c/Lsil03q9UT-000007 type=Symfonium/Android username=vurt
time="2025-02-15T21:58:00Z" level=trace msg="SQL: `UPDATE player SET client = {:p0}, id = {:p1}, ip = {:p2}, last_seen = {:p3}, max_bit_rate = {:p4}, name = {:p5}, report_real_path = {:p6}, scrobble_enabled = {:p7}, transcoding_id = {:p8}, user_agent = {:p9}, user_id = {:p10} WHERE id = {:p11}`" args="map[p0:Symfonium p1:49609f78-1c61-42ce-ad26-dcf1b96d8f67 p10:e7d2b8f5-f9e8-4612-a178-37c3b3a82465 p11:49609f78-1c61-42ce-ad26-dcf1b96d8f67 p2: p3:2025-02-15T21:58:00.505022554Z p4:0 p5:Symfonium [Symfonium/Android] p6:false p7:true p8: p9:Symfonium/Android]" elapsedTime="779.533µs" requestId=83a493bc950c/Lsil03q9UT-000007 rowsAffected=1
time="2025-02-15T21:58:00Z" level=warning msg="API: Failed response" endpoint=/rest/updatePlaylist.view error=10 message="missing parameter: 'playlistId'" requestId=83a493bc950c/Lsil03q9UT-000007
time="2025-02-15T21:58:00Z" level=debug msg="HTTP: GET http://xxxxxt/rest/updatePlaylist.view?u=vurt&t=[REDACTED]&s=[REDACTED]&v=1.13.0&c=Symfonium&f=json" elapsedTime=2.5ms header="{\"Accept-Encoding\":[\"gzip\"],\"Connection\":[\"close\"],\"User-Agent\":[\"Symfonium/11.6.0 (Linux;Android 15)\"],\"X-Forwarded-For\":[\"192.168.1.1\"],\"X-Forwarded-Host\":[\"xxx.xxxx.net\"],\"X-Forwarded-Method\":[\"GET\"],\"X-Forwarded-Port\":[\"443\"],\"X-Forwarded-Proto\":[\"https\"],\"X-Forwarded-Server\":[\"xxx.xxxx.net\"],\"X-Forwarded-Ssl\":[\"on\"],\"X-Forwarded-Uri\":[\"/rest/updatePlaylist.view?u=xxx&s=xxxx\\u0026v=1.13.0\\u0026c=Symfonium\\u0026f=json\"],\"X-Original-Method\":[\"GET\"],\"X-Original-Url\":[\"https://xxxx/rest/updatePlaylist.view?u=xxxxx&s=xxxx\\u0026v=1.13.0\\u0026c=Symfonium\\u0026f=json\"],\"X-Real-Ip\":[\"192.168.1.1\"]}" httpStatus=200 remoteAddr=192.168.1.1 requestId=83a493bc950c/Lsil03q9UT-000007 responseSize=199
Beware you have exposed your host and a login / password hash in those logs.
@deluan maybe you can redact the proxy data too?
?u=vurt\\u0026t=xxxx\\u0026s=xxx
Anyway @vurt those logs shows that the proxy remove the content-type header and seems to say the request was a get when it was a post.
Try to connect without the proxy to see that all works correctly then try to figure out how to fix the proxy configuration to work with Navidrome.
Thank you very much @Tolriq , I’ll take a look at nginx.
(I don’t recognize which are the login/password hash!)
