Hi Tolriq,
I am experiencing a playback failure when trying to play native DSD (.dsf) files on a FiiO M15S DAP running Android 10 (API 29) in Symfonium 15.1.0.
Environment & Configuration
Device: FiiO M15S (sdm660_64, Android 10 / SDK 29)
Symfonium Version: 15.1.0 (127812)
Source: Navidrome 0.64.2 (OpenSubsonic direct play via format=raw, DSD64 2.8224 MHz .dsf file)
Output & DSP Settings: Wired headphone output, all DSP/EQ/ReplayGain/Crossfade features disabled, “Force PCM for DSD” disabled.
Issue Description
When attempting to play a .dsf track without PCM conversion, Symfonium selects playbackPipelineMode=VendorNativeDsd (localPlaybackBackendId=fiio-dsd-audio, transport=NativePacked) and immediately fails to initialize the AudioTrack because Android 10 on the M15S rejects encoding 254:
Subsonic (Open)
2026-11-19 22:13:46.114 Verbose/Logger: Information: sdm660_64/sdm660_64/29/10/FiiO M15S/qti/0/true/92/126/17 - com.android.vending
2026-11-19 22:13:46.118 Verbose/Logger: Information: 15.1.0 (127812[arm64-v8a,armeabi-v7a,armeabi])
2026-11-19 22:13:51.682 Verbose/MediaPrepareManager: … playbackPipelineMode=VendorNativeDsd, localPlaybackBackendId=fiio-dsd-audio, selectedDirectAudioTransport=VendorNativeDsd, generatedDsdOutputConfig=null, directDsdOutputConfig=DirectDsdOutputConfig(routeFamily=VendorNativeDsd, carrierSampleRateHz=88200, channelCount=2, transport=NativePacked, bitOrder=LeastSignificantBitFirst)
2026-11-19 22:13:51.756 Verbose/AudioEngine/29: onAudioInputFormatChanged: mode=VendorNativeDsd format=[mime=audio/raw/sr=88200/channels=2/enc=22/codecs=dsd_lsbf_planar]
2026-11-19 22:13:51.757 Verbose/FiioDsdAudio: FiiO DSD mode enabled sampleRate=88200
2026-11-19 22:13:51.758 Error/FiioDsdAudio: Unable to create FiiO DSD output
java.lang.IllegalArgumentException: Invalid encoding 254
at android.media.AudioFormat$Builder.setEncoding(AudioFormat.java:1048)
at android.media.AudioTrack.(AudioTrack.java:554)
2026-11-19 22:13:51.765 Error/ExoPlayer/29: playerFailed [eventTime=208.78, mediaPos=0.00, window=0, period=0, errorCode=ERROR_CODE_AUDIO_TRACK_INIT_FAILED
sm3: MediaCodecAudioRenderer error, index=0, format=Format(null, null, null, audio/raw, dsd_lsbf_planar, -1, null, [-1, -1, -1.0, null], [2, -1, 88200]), format_supported=YES
Caused by: mc0: Unable to create FiiO DSD output for Format(null, null, null, audio/raw, dsd_lsbf_planar, -1, null, [-1, -1, -1.0, null], [2, -1, 88200])
Caused by: mb0: java.lang.IllegalArgumentException: Invalid encoding 254
netkof
