My homescreen is completely empty,its not showing any songs and the sync button on top right is greyed out , please fix the issue ,i checked its latest version,i forced stopped and started the app and even cleared cache . please help.
Upload description: Madbod93g
Tolriq
December 2, 2024, 1:11pm
2
By fix the issue you mean point you to the message repeated a lot on the home page explaining to fix your filters ?
Symfonium offer a consolidated view of all your media providers and their libraries.
There might be times where you want to filter the visible data to only show specific libraries or media that are only available offline for example.
If you enable the Available offline filter, then only media that are cached locally will be played.
Note: A lot of screens also have contextual filters that only apply to them. See Sort, filter and configure display modes in library views
You can do that easily …
You have hidden your provider, just click the card again to unhide it ? (The crossed eye should indicate that it’s invisible as per your actions.)
Thank you ,i feel really dumb😞 for opening this issue.
Thank you for instant reply .
