When you select a track the circle will rotate around the play button, and it will switch between play and pause until it just quits. Then hitting play will do nothing
Navidrome
Set up your Navidrome server and then try to play a track
Debug log maybe captured problem uploaded as drezin
I couldn’t find the upload named “drezin” around the date of your report. Could you send debug logs using this guide?
Enable debug mode, select a track, let the problem happen, then try Play again. Disable debug mode and upload the logs promptly. Reply here with the upload description and the time the problem occurred so I can find the right logs.
Could you paste the exact filename or upload description shown in the screenshot here, along with the time the problem occurred? I still can’t find a matching upload under “drezin”, and I don’t see the screenshot in this topic.
