Music Player Randomly Stops
If I start listening to an album from the first track, it stops playing after the first track till I hit next manually.
Same thing happens when I’m listening to a track and I pause the track and resume, it stops playing at the end of that track until I press next manually.
Upload description: Music Player Randomly Stops.
Screenshot 1 is what the app looks like when the track stops playing.
On the new beta 1 for version 13.6.5, start playing an album from the first track and it’ll stop immediately at the end of the first track until you press either next or previous manually.
Can you give more details about the repro steps ?
I exclusively listen to albums starting from the start, so there’s something else at play here.
That’s it, honestly. I just tap on a song and once it runs till the end of the song it stops. Even it doesn’t matter if it’s the first track in an album, just touch on any song and once it runs till the end of that song it stops playing.
For example this song is #8 on the tracklist and it still performs the same defect.
Also want to point out that whenever this happens, the play/pause button becomes unpressable.
This has just started happening to me as well. Any album I play, it stops after playing just one track. I have to manually go to the next track, then the same thing happens. I’ve cleared cache etc… same thing happens.
Just realised this is the same issue I just submitted.
I confirm the issue. Occurs when listening on phone and also while using Android Auto.
I was about to report this same issue. Glad it is fixed, although I don’t see it listed in the 13.6.5 beta 2, and I still can repro the issue. Hopefully we can see the fix in beta 3.
It’s supposed to be fixed. Provide new logs and a repro.
It’s fixed for me and I haven’t been able to reproduce.
Ok, I’ll make sure I have the latest, do more testing and provide new logs if I can repro. Thanks.
There’s no B3 planned so please be fast :wink:
Fixed for me too….
Playback seems fine now
So far so good, I had to restart but everything looks good using bluetooth and Android Auto. Thanks.
