Issue: Symfonium consistently does not read any of the MP3 tags, but consistently only for some files: e.g. Track number, Album, Artist
Symfonium Version: 10.1.5B1 (12667) Also noted on the latest stable Synfonium release. Paid
Environment: Samsung S10 Android. Also tried Samsung J8 Android, same issue
Log File: Attached. Log covers a sync of the source, with only a single album loaded as an example, where it appears the MP3 file tag data is not being read
Succeeded: 01 It seemed like a good idea at the time.mp3
Failed: 04 The ride to Agadir.mp3
Source: Local SD card. Identical issue noted with the same files read and not read when using WebDav alternative.
Detail:
The MP3 tags are not being read for a small percentage of files.
The files were ripped by different methods (Windows Media Player, Audacity, and others), and some files within the same album are read, others not.
The tags are definitely present, verified with MP3Tag, and Windows, and editing the tags does not change the issue. Accordingly the issue appears to be file related, since most files read consistently, as much as the files that don’t read fail consistently.
Puzzling is that one cannot repair the issue by editing the tags with MP3Tag, or others.
Upload description: redacted
