It would be nice for the app to allow for different actions based on pressing strings separated by the \t action. Right now, I have it set up so that a tap on any of the two separated strings opens the queue, but would it be possible for a tap on the left-hand string to open the queue, but pressing the right-hand string opens the album of the currently playing track?
In addition, is it possible to access the next.artist and next.album values as an icon or action that you can add to the Now Playing screen or to a string, so you can tap and go to the next artist or album?
Finally, is it possible for a short press on the top bar to perform one action, but a long press initiates another? E.g: short press to open artist, long press to open album. It seems to only be implemented for strings in Controls and Information.
It leaves my Now Playing setup a bit lacking
More customisability for the Now Playing screen
I’m pretty sure I explained it well, but I can go more in-depth in the comments
