More FLAC tracks not playing through
Today it seemed like there was at least one track that wouldn’t play through on every album I listened to. I did send in a log if that helps. Server is navidrome, and I’ve verified that the same track & file play through fine in the web browser, as well as multiple other players. I’ve zoomed all the way in with Audacity and I don’t see anything that looks like corruption. flac -t reports no issues. Yet, the attached track reliably stops at 2:57 every time it’s played back. This happens with both the internal and the offloaded decoder. The rest of the file will play fine if I manually “bump” the play progress bar past 2:57.
Please see if you can find the issue with the file, and hopefully a reliable way to identify tracks with errors so that I can “fix” or replace them. I have not been able to find any way to identify the tracks other than just coming across them with Symfonium when I try to play them. But again, this example is playable with every other player I have tried and has passed any kind of test I’ve used on it.
Or maybe there’s something in the log (I didn’t see anything that stood out as an error) that points to another issue.
https://bucket.digitalsand.photography/index.php/s/TnQ93Q2NKqYAy3i
Thanks
Upload description: ben-mrpc
the md5sum from ffmpeg and metaflac also both match for the posted file. Could it be a navidrome issue?
Oh… I may have been a bit dumb here. It looks like I turned off “offload” mode, rather than “prefer internal,” I now have prefer internal checked and the song played through the 2:57 point.
In my defense, I was driving while fiddling with it (which, also, maybe not be best lol).
Hopefully no more “bad tracks” :crossed_fingers:
Some more info… It seems that when I come across a track that fails to play, if I clear the playback cache and remove any offline cache of the file, then try to play it (fresh copy from the server), it plays fine. So there may be some corruption happening in the cache / cache process.
I have been able to do this multiple times with success, so it doesn’t seem to be a one off luck.
