More features for Playlist
I wanted to propose a few features for Playlists :
1). Give a feature for Continue Playlist Listening on Home Screen in Symfonium .. I was listening to some songs and then i changed to another album different from playlist , can you give a option to continue Playlist Listening on Symfoniums Home screen ?
2). Can you give a option to select multiple Tags in Playlist page , right now we can only select 1 Tag at a time.
3). Could you also give a option to add a small image or Colour to Tags as it all feel the same , like some colour’s changes would look good !!
4). As of now in Home Screen Navigation there isn’t a option to list playlist Tags , only Album Tags and Artist Tags !!
If you add Playlist Tags in Home screen , then adding a image to that Tag would definitely look too good !! Well if possible … :smirking_face:
5). Could you give a option to sort /change Tracks (like change it dynamically → move up or down ) as we want in smart playlist , and also i don’t see a option to filter out with Release date , like newly released should be on top and then the others , if this option is there , kindly guide me , I would be greatfull !! Thanks for considering .
Easy Navigation
Enchanced User Interface
Adding Playlist Tags in Symfonium Home screen would be cool .
It would be like creating a Main Folder (Tag with images) and then add sub folders ( Multiple playlists).
Thanks for considering thanks !!
