More detailed display of "intelligent queue" and "intelligent routing(?)" within the actual player
Hey! First of all, thank you for the app! It’s great :slight_smile:
I got one small suggestion:
I want a more detailed display of the “intelligent queue” and “intelligent routing(?)” feature within the player.
Here are 2 screenshots and one video to show what I mean:
https://imgur.com/a/YBcYWKR
Right now, it doesn’t display which mode of “intelligent routing(?)” I am on, it just says OFF because the “intelligent queue” is off. You always need to click on it first to see if and what is active.
Here is a short video of how it is right now:
https://streamable.com/sfijix
I also tried setting it to 2 lines. We could make it so that this additional info only shows when you select “2 lines” or more for this. 1 line and it only shows intelligent queue, as it is right now.
Benefit:
You always know if a specific routing feature is active and you don’t have to click on it to see it.
Thank you! :slight_smile:
What display string do you use ?
There’s custom strings “smartflow” and “smartqueue” to display both as you want.
Oh, thanks for the fast answer!
I did it like this, and it works. It displays correctly… but it isn’t clickable anymore.
Ideally I just want it to display it more detailed as in my mockup screenshot above.
Probably I just need to set it to 2 separate lines then…
EDIT: 2 SEPARATE LINES do the trick, but it’s a bit inconvenient in my opinion. I didn’t know about all the custom strings, sorry! You can move this thread into tips and tricks probably. Thank you!
Take time to check more that section. You can configure click action on custom strings, display multiple custom strings on the same string with multiline or not and much more.
