I think it could be helpful to allow any number of alternate connection sources. Currently there is a primary and secondary, but a list that allows for more than two connection sources would be really helpful for my niche use case.
For a single source, I have more than two possible connection endpoints for my subsonic server. I have a local url, a url that is accessible via VPN, and a third public facing url. In my situation, I am not always home. My public IP can change, breaking the public facing url. I have a backup VPN connection that can be used if the first two are unavailable, but there is no way to add more than two connection sources.
This feature would allow users to add more endpoints for their server, which can improve connection reliability as there are more endpoints to fall back onto.
Immich has a great solution to this. The connection sources is a list, where each list entry has a potential url. The higher the entry is in the list, the higher priority that connection has. This way, I can prioritize my local url, then the public facing url, then the backup vpn url, and add even more connection sources if needed.
