Please add a way to access the “more actions” menu for any song in the queue, not just the currently playing one. Right now the three dots menu only includes “Play next” and “Remove”. The menu items could be either added to the existing menu (below a horizontal bar), or added to a submenu (if feasible).
I often find myself in the Next Up / queue screen, trying to like a song that is further down the queue, or go to it’s artist/album. All of these options are available from the Now Playing screen (three dots menu), but in order to use that, the song has to be playing. I don’t see a reason why most these actions shouldn’t be available for any song in the queue (except for the first 5 actions including playback speed, skip silence, sleep timer, etc. Instant mix should be included though).
Allows the user to perform the same actions on songs, regardless if they are scrolling through their library or the queue. Makes the queue more useful, as all songs can be properly interacted with.
Youtube Music let’s the user do exactly this. Most importantly, the user can go to artists/album and like the song:
I think Finamp also works this way. Same for SoundCloud.
Long-pressing a song in the queue should also open the menu, this currently doesn’t work, not even for the play next / remove actions. Right now, long pressing simply does nothing…
Add these options:
To this menu:
Hope this isn’t too complicated!
