Mono Audio
The ability to toggle mono audio on and off within the app, preferably in the same way that EQ is implemented, where it can be assigned to certain profiles for devices.
I appreciate my case is pretty niche and might not be possible but if you don’t ask you don’t get.
I am deaf in one ear and need to switch to mono audio when listening with headphones/earbuds. However I don’t want mono to be on when using Android Auto or a bluetooth speaker where it isn’t needed.
Having a customizable toggle that can activate mono when connected to my earbuds, but disable it when connected to my car or BT speaker automatically would be great and save me the hassle of having to dig through system menus to turn mono on and off all the time, depending on what I’m listening through.
I think having a mono toggle would also be useful for other users that tend to listen with only one earbud in at a time, but want a quick toggle to switch back to stereo when they use both.
The best solution would be to use Tasker or Automate to automatically toggle the OS setting for you depending on where you are playing.
This would solve the issue for all the apps and use cases.
