18/75 locally stored albums will not pull any track number data from embedded tags.
All albums have been processed and tagged the same way.
Upload description: missing track number tags (nerdening)
Love the program so far. Just this one first-world problem and it’s perfect
Initial sync showed albums with missing tags.
Removed local device as a source and re-added as a source and re-ran sync.
Fixed some albums, but not all.
Tolriq
January 10, 2025, 4:54pm
2
Please provide logs containing a sync and one of those files.
If your tool that edit tags does not change timestamp you may need to clear tag cache in the provider settings.
I apologize in advance, but I hope I did the sync log correctly? I’m also unsure of how to send you one of the files.
I may have messed up the sync log because I didn’t toggle off debug mode when I ran it yesterday.
Tolriq
January 11, 2025, 8:27am
4
In the logs the files don’t have the proper tags in the cache but when testing the file they have.
As said above go to the provider settings and press clear tag cache, then provide new logs when scanning but it should work.
I un-installed and reinstalled Symfonium and during the initial scan I turned on debug mode.
Of note, once it got to 33,000 files or so, my phone had troubles and minimized and or closed the app.
It also soft-reset my phones desktop, like when you would experience when you end-task Windows Explorer.
After the fresh install of the app and scan the same artists album are still missing track numbers.
I hope the initial scan came through in the logs I just sent.
Tolriq
January 11, 2025, 5:34pm
6
tags={COM=[], AR=[The Fratellis], GEN=[], RDT=[2013], AL=[We Need Medicine], TIT=[Halloween Blues]},
Those are the tags present in the file scanned by the app.
This is not at all the same file you uploaded here. You probably did not copy the proper file at the proper place after the edit.
