MINOR - Playing Incorrect Track When Selecting Second Song in Playlist
System info:
  • Plex 1.32.1.6999
  • Galaxy S23 Ultra
  • Android version 13
  • Symfonium version 5.3.0 (also impacted previous version)
Pretty minor issue. If shuffling is enabled, selecting the second song in a playlist (smart or normal. Read-only or writable) a random track in the playlist will be selected instead. When in debug mode, I can see briefly that the second song (in my case, California Dreaming) gets selected, then switches to a different track.
The intended behavior is for the selected track to be played, the shuffle should only happen after the track finishes. Instead, it seems to be shuffling prematurely.
The second log is smaller, only me starting the second track once. Instead of “California Dreaming” it plays “Lost” which you can see in the logs.
debug-20230515_164705.zip (64.6 KB)
debug-20230515_170844.zip (13.4 KB)
Thanks so strange small race in Compose due to pager animations :frowning:
Will postpone workaround to after I migrate back to the non accompanist pager when official solution is bug free. (Technical but used as a note for me :stuck_out_tongue: )
