For a song to be considered as most played, it should have at least a minimum of 2 counts but the “Most played tracks” section at home is limited to 1.
My suggestion is to rase it to a minimum of 2 or to add an option to change this value by the one any users desires in the “Playback” section of the “Playback settings” section.
Any song that was played only once and never played again appears in that list, therefore, if the count is raised to 2, only songs that have been played twice or more will start appearing in the list.
The list will only display songs with 2 or more counts which will avoid having a long list of songs played only once.
This will helps to understand how many times a song was played without even noticing before.
You can achieve this by creating a Smart Playlist with a Play Count rule (greater than 2) and Sort by “Play count”.
Once you have the Smart Playlist, tap on the three dots and search for “Add to home page”. This new section will be available to edit and customize in the Home configuration
@trisk4y I just wanted the “Most played tracks” to have a minimum of 2 counts to display songs or to have the ability to change that number, that’s all.
@trisk4y Don’t try to discuss with @branches78 he always know and never reads, he was like that before and seems it’s still the same, his needs are the only needs that could exist and the app default should be exactly as he wants he should not have to press buttons
@branches78 as we both told you this is the way, the default rows are template, you can create your own rows with your own rules, but that would require that you read and used search instead of just knowing.
No need to answer, I already warned you and will have 0 patience after your return.
