I would like to know if its possible to play music from Minimserver? I have it running in docker on a synology NAS on local network.
Enjoying the app and this would be the icing on the cake to liberate me from BubbleUPnP!
the highly customisable playback of network stored music
Tolriq
March 27, 2024, 10:02am
2
Do yourself a favor and move away from UPnP and install LMS GitHub - epoupon/lms: Lightweight Music Server. Access your self-hosted music using a web interface.
You can run it in 2 seconds in a container on your Synology and will find it’s much better.
Anyway this is a duplicate there’s no plans to support UPnP as a server as it’s just the worst possible protocol and does not fit the needs for Symfonium.
Hi Tolriq,
Thanks for the super quick reply and suggestion.
I have a couple of questions
Does LMS allow the customisation of presentation of your music library that MinimServer does?
Do you know if LMS works with Moode player?
Regards,
