Menus Elements not working?
Hi there !
First of all, thanks a lot for this app ! I’ve set up a Navidrome (subsonic) server a month ago, and I’m still looking for an app for my phone that will mostly fit my needs.
So far I’ve tested :
  • substreamer: best UI, but way too slow for my phone, and hangs sometimes without playing
  • Dsub: old and somehow outdated UI, but the most reactive and stable
  • Ultrasonic: UI slightly better than Dsub, some interesting features like star rating, very reactive, but for some reason I can’t play anything (even If I can browse the server and rate tracks without any problem)
Your app seems to be the best I’ve tried so far and I’ll happily pay for it (except for the bugs, hence this thread): I love the UI, it’s reactive and full of nice features (even if some that I’d like are missing, but I’ll create a separate thread for that), but lots of menus elements are not working :confused: I’ve circled them in the screenshots below
Nothing happens when I click on these menu elements
  • Android 8.0.0
  • Samsung A5 2017
The app think you are trying to cheat the trial and so is in blocked mode.
It’s strange because the logs shows 2 different data that should not be possible at the same time. Did you do something special?
You can clear the app data and start fresh it should fix this.
I did nothing special:
  1. installed it from Google Play Store
  2. launched it and logged in to my server
  3. went to the settings and changed some settings (cache directory and probably other stuff)
  4. tried to use the other menu elements, but without success
  5. went to settings and press “clean internal state” (not sure of the translation) to check if it would solve something
and that’s pretty much it.
For the “cheat the trial” part, I don’t know how it’s happening since I clearly don’t see how to do that, maybe it has something to do with Blockada ? Anyway like I said, I would happily pay for it if it was working fine and with a few other missing features.
I’ll try to disable Blockada and I’ll keep you posted
You may still need to clear the app data for it to recover from it’s state.
