Memory cache problem
Moto G 2025 phone, updated app. A song plays fine, then around half way through I get a spinning circle, like it runs out of memory cache. I have a 5G mobile connection with plenty of storage space. Playback cache is almost 3GB. Is there any way to increase the memory cache? I had a Pixel 4a that didn’t used to have this problem.
In the log I sent, it happened in the first song.
Upload description: tacrec
It seems to happen with songs over 5 minutes long. Shorter songs seem to play without a problem.
 Caused by: java.net.SocketException: Connection reset
Do you use an HTTP/2 proxy like Apache? This is usually because of an issue between the proxy and Jellyfin causing timeout and closing of the connection.
You can usually increase timeout values of the proxy or disable http/2 in Settings/Playback/Advanced.
I don’t use HTTP/2 that I know of. Should I force HTTP/1.1?
I think I already answered that above :wink:
Either fix the proxy or try the option to workaround.
I tried 1.1 and it looks like it will work, thanks.
