Android Auto supports showing a media widget on screen when other apps is taking the main area of the screen (for example, navigation).
It would be good to be able to see the music currently playing on the screen any time.
It makes the app on par with many other media apps that do support media widget.
For example, BlackPlayer has this media widget. It shows control buttons on it, but briefly displays the track information when switch track.
Tolriq
March 8, 2023, 11:41am
2
It’s already the case unless you disable the media session in the advanced settings.
Edit: You probably have migrated to Coolwalk and the interface is updated for modern apps.
Thanks for your reply. It’s weird. Previously when I was using BlackPlayer it just worked. I’ll have a closer look into the settings and see what needs to be enabled.
Tolriq
March 8, 2023, 12:47pm
4
It does just work unless you disable something in the settings.
But Google have updated Android Auto UI recently to Coolwalk so what you are looking for is probably just no more here and different.
