Media starts and stops during playback
When I play audio, my file starts playing, then the audio cuts out. After a few seconds the audio comes back, but it’s skipped to a later time in the file. This happens several time before skipping to the next song. This happens on multiple files that play just fine on Plex on my Nvidia Shield Pro.
Android TV
Plex
  1. Open Symphonium
  2. click a track or album
  3. select “instant mix” or “radio mix”
  4. track starts to play, but begins to cut in and out
I tried changing various cache options, but none helped (enable rolling cache, increase size of internal storage for cache, enabling Playback cache size and changing pre-cache to 10 tracks, force first song pre-cache).
I also checked that I have all Equalizer - DSP settings disabled (as per default), and I tried disabling "Prefer internal decoder). Neither helped.
Transcoding engine is turned on.
Most options are set to their default. Most options I’ve changed are aesthetic only.
I don’t remember any of this being a problem during my trial. I’ve submitted logs via the ap itself.
rystheguy
2026-04-19 12:40:47.814 Error MusicPlayer  DataSource: Error reading source (2/10/true), retrying [sz3: java.net.ProtocolException: unexpected end of stream]
Check plex logs if there’s something special. Do you use a proxy ? You can try to disable HTTP 2 for playback in the settings too.
Thank you for the response. Those didn’t fix the problem, but I think I managed to fix it by disabling the “Match content audio resolution” on my Nvidia Shield Pro. I’m not sure why that would have fixed, though.
